winglesss Joined Forum - Ordering 2021 F-250 XL
This order submission for this F-250 XL is imminent, probably before week end.
The primary usage will be infrequent popping around town, but has been configured for short or longer hauling of two horse or four horse gooseneck trailers.
The vinyl seating and rubber flooring are intentional, for easy cleaning and not being damaged in a dirty environment.
Looking forward to exchanging information w/ the members.
$45,615 Configured List Total Cost
$37,820 2021 F-250 XL, Crew Cab, 6-3/4', SRW
Included Race Red
Included 6.2L 2-valve SOHC Flex Fuel V8
Included 4X2
Included TorqShift Heavy-Duty 6-Speed SelectShift Automatic Transmission
$390 3.73 Electronic Locking Axle Ratio
Included 10,000 / 9,900 GVWR Package
$160 Camper Package
$1,075 Power Equipment Group
$1,825 STX Appearance Package
Included 18" Sparkle Silver Painted Cast Aluminum Wheels with Bright Hub Cover and Center Ornament (SRW)
$500 5th-Wheel / Gooseneck Hitch Prep Package
$595 Bedliner - Tough Bed Spray-in
Included Center High-Mounted Stop Lamp (CHMSL)
$210 Dual Battery
$250 Hitch Kit Gooseneck
$95 LED Roof Marker / Clearance Lamps
$115 Pre-Collision Assist with Automatic Emergency Braking (AEB) and Forward Collision Warning
$60 Rear Window - Defrost with Privacy Glass
$325 Wheel Well Liner - Front / Rear
Included LT275/65Rx18E BSW A/S Tires
Included Manual-folding, Manual-Telescoping, Power Glass Trailer Tow Mirrors with Heated Glass and Heated Convex Spotter Mirror
Included Heavy Duty Vinyl Medium Earth Gray
Included HD Vinyl Split Bench 40/20/40 Front Seats
Included 110-Volt/400-Watt AC Outlet
Included Cruise Control
Included Floor Covering - Carpet Delete
$270 Integrated Trailer Brake Controller
Included AM/FM Stereo with MP3 Player
$450 SYNC3
Probably going to add / install the unobtainium on XL $1K OEM Ford NAV module after the vehicle arrives onto my SYNC 3 XL. The install looks easy enough and the cost is acceptable. Plus I don't need / want the options / charges associated w/ changing to the XLT so I can get this installed by Ford.
