Sponsored by: Real Truck
Intermittent electrical issue
Old Dec 30, 2020 | 04:42 PM
02fanatic's Avatar
02fanatic
So I have a 2006 F350 SuperCrew with a 6o diesel. I started having problems with my instrument cluster how about a month ago it completely shuts down. Along with the radio and all window controls. It's a Lariat Edition. Is it an ECM issue?
Old Dec 30, 2020 | 05:02 PM
projectSHO89's Avatar
projectSHO89
Is it an ECM issue?
Nope. It's probably a power issue.
Old Dec 30, 2020 | 05:23 PM
02fanatic's Avatar
02fanatic
Okay thank you. I'm sure there's a power control module or something that is causing this. Just don't know where to begin
Old Dec 31, 2020 | 08:20 AM
NoelCT's Avatar
NoelCT
Take a look at your battery ground wire(s) and connections. Make sure you have clean, tight, and solid, corrosion free contacts at battery and termination points. Make sure battery is properly anchored too. Bouncing and shifting while driving can tug on wires momentatily and cause intermittent issues.
Good luck.
Old Dec 31, 2020 | 11:48 AM
projectSHO89
Focus on the power and ground feeds specific to the instrument cluster.
IIRC, the Accessory Delay Relay which provides power to the audio and power window systems, resides in the cluster. If the cluster goes "offline" for any reason, so do the subsystems that it provides power to.
Old Dec 31, 2020 | 07:19 PM
02fanatic's Avatar
02fanatic
Thank you for the information. I'm an absolute idiot when it comes to tracing this stuff down
Richwon4
Jun 23, 2016 10:44 PM
Sondre Næss
Apr 20, 2016 03:35 PM
swellman
Mar 23, 2016 07:47 PM
Redlineundefined50
Oct 25, 2014 05:15 AM
