Electric running boards not working
Old Dec 30, 2020 | 02:30 PM
Cablemandan's Avatar
Cablemandan
Hello everyone, just joined this forum snd have a issue with my 2017 f150 KR power running boards
just changed a bad battery in truck ( varing voltage issues) and now one is stuck open and one closed
In advanced settings the icon will not move from off?
have tried numerous battery resets etc.
Any ideas ?
Old Dec 30, 2020 | 03:11 PM
JKBrad's Avatar
JKBrad
Welcome to FTE.
Open both doors and disconnect the battery. Then turn on a headlight switch. Leave it that way for 20 minutes or so. Then turn off the headlight switch, reconnect the battery and close the doors. Hopefully they will both go up.
Old Dec 30, 2020 | 04:45 PM
Cablemandan
Originally Posted by JKBrad
Welcome to FTE.
Only my drivers side is down, passenger is up
should I just leave the drivers open ?
Old Dec 30, 2020 | 06:45 PM
T diesel's Avatar
T diesel
Maybe this video will help.
Old Dec 30, 2020 | 07:11 PM
Cablemandan
Thanks for the video but have been through just about everything on the internet so far
its not a mechanical issue, it’s electrical
by the way, the lights on and battery disconnect did nothing but thanks for trying
Old Dec 30, 2020 | 07:39 PM
JKBrad's Avatar
JKBrad
The idea is to have them both down when you disconnect the battery so that hopefully they will retract at the sale time.
Old Dec 30, 2020 | 10:25 PM
KJ Smith's Avatar
KJ Smith
On my '13, I disconnected the battery once.
From that point until I sold it the left board would stay down twice as long as the right.
Never was able to find out what the issue was.
Hope you have better luck with yours.
Old Dec 31, 2020 | 09:22 AM
Cablemandan
so do I
believe it may be a fried RBM module
but not sure
Old Feb 5, 2021 | 07:24 PM
dm37b's Avatar
dm37b
Any ideas ?
Did you find the solution ?
I have same issue
Old Feb 5, 2021 | 07:39 PM
Cablemandan
I have same issue
actually I finally took in to ford
they said there was two shorts , and traced one to the drivers seat massage system relay, pulled it and it cleared up, never really found out what other was but they did say I might have reinserted the fuse for the running boards into the wrong spot as I was trouble shooting
I may have as I was trying soooo, many thing’s especially when was having the battery issue
so I guess the bad battery caused the running board issue maybe and I messed up on the fuss🤔, still not convinced, but the seat message issue was shorting the battery but my battery was definitely bad, shorted cell
Conclusion, take to dealer, they have done special diagnostic tools to deal with
FYI, my total bill for most of a day , $90!!
Old Feb 7, 2021 | 01:36 AM
RGrew176's Avatar
RGrew176
One thing my friend a mechanic told me when I bought my new 2020 F-150 was if I ever had to put a charger on the battery make sure I disconnect both cables first so the charger is only running power into the battery.
edjunior
Dec 5, 2020 01:51 AM
Scott Akers
2009 - 2014 F150
Sep 3, 2019 08:51 PM
Larryj1999
2009 - 2014 F150
Oct 9, 2017 07:34 AM
sgcraven
2009 - 2014 F150
Sep 17, 2016 03:20 PM
