Wheel threads
Old Dec 30, 2020 | 01:05 PM
tuff_baer's Avatar
tuff_baer
Wheel threads
Have a 2015 f150 that I want to add 18mm wheel spacers to. Want to know if I should install longer wheel studs and if so which ones, or if I should be fine with the stock ones.
Old Dec 30, 2020 | 01:12 PM
ford390gashog's Avatar
ford390gashog
You can't do a 18mm spacer safely. You would have to go to a 1.5 spacer that keeps it hub centric.
Old Dec 30, 2020 | 01:15 PM
tuff_baer's Avatar
tuff_baer
custom offsets has a wide range of spacers including made to order hub centric 18mm spacers so thats not a concern for me
Old Dec 30, 2020 | 06:22 PM
CJM8515's Avatar
CJM8515
never ever ever spacers. the studs can snap, the nuts can unthread, etc. but the proper offset wheels
Old Dec 30, 2020 | 06:54 PM
tuff_baer's Avatar
tuff_baer
buddy I didnt ask your opinion on spacers
Old Dec 30, 2020 | 07:58 PM
JKBrad's Avatar
JKBrad
If you ask questions on a forum, you will get opinions. My opinion is that a slip on spacer is bad. But, if you must, no more than ,25”.
The thickness you want will leave too few threads exposed to properly torque the lug nuts. Bolt on spacers are okay if they are hub centric, and torqued properly with thread lock, then checked regularly.
If you want to buy the Custom Offsets spacers, ask them about ordering longer studs.
Old Dec 30, 2020 | 08:03 PM
CR172's Avatar
CR172
Pretty uppity for a newbie. And by the way..... I agree with the no spacers. Lazy man's way of pushing wheels outward for Gawd knows what reason. Tires protruding past the fenders looks stupid IMO and throws crap all over the sides of the truck.
Old Dec 30, 2020 | 11:27 PM
nddragon01's Avatar
nddragon01
Lol, someone's on the rag.
Old Jan 1, 2021 | 12:40 PM
CR172's Avatar
CR172
Guess tuff_baer ain't so tough........
Old Jan 9, 2021 | 07:35 AM
cullenkyla's Avatar
cullenkyla
Could it have been they drilled for the fifth wheel and did not install. Found out it wasn't ideal on a f150 and traded it back for a f250 possibly
Last edited by cullenkyla; Jan 9, 2021 at 09:54 AM. Reason: In the wrong tread could someone move it thanks
tlrtucker
18
Oct 3, 2019 02:41 PM
tojoski
May 9, 2011 09:30 PM
mikedeason
Sep 29, 2005 10:54 PM
