Factory remote start question!
Old Dec 23, 2020 | 10:41 AM
Slowjoe6969's Avatar
Slowjoe6969
I am curious to know if anyone can tell me how many consecutive remotes starts they can make on there 2017-2019? My 2017 with aftermarket I could start it as many times as I wanted, but my 2020 has the factory remote start which the 17 didn’t. But I can only start it twice (or maximum of 30 minutes) then it has to be started by key. So the reason I am asking is if this is a change in the BCM, it might be an adjustment that can be made in Forscan.
Old Dec 23, 2020 | 01:29 PM
Rjacks258's Avatar
Rjacks258
I start mine sometimes more often than that. Especially when I had it set to shut off at 10 minutes. 3-4 times in less than 30 once or twice. Mostly twice almost every morn.
Old Dec 23, 2020 | 01:33 PM
GNR22's Avatar
GNR22
In my '14 I could only start it 2x in a row and then it had to be done by the key.
I don't have any idea what my '21 will let me do. I have it set to remote start every morning with the app. The first day it idled for 10 minutes and then shut off. I remote started it using the keyfob and then took off within the next 5 minutes. Yesterday it idled for 15 minutes and shut off (which is what I have the remote start duration set to in the dash) and shut off. I tried to remote start it with the key fob and it just honked at me, no dice. This morning it idled for 19 minutes continuously before I left for work. No clue how it is supposed to work.
Old Dec 23, 2020 | 01:38 PM
JayCarver's Avatar
JayCarver
My 2020 will only allow 2 starts (15min each). It would be great if we could figure out how to bypass it to let us start as much as we want.
Old Dec 23, 2020 | 01:42 PM
MKrenn's Avatar
MKrenn
I would say check these 2 parameters in FORscan:
726-25-01 xxxx xxxx x*xx Feat_Cfg [REMOTESTARTDURATION] [VEHICLE] ENUM: 0=OFF 1=MIN5 2=MIN10 3=MIN15
726-28-01 xxxx xxxx x*xx FeatLst_to_BCM_Feature_InitVal [REMOTESTARTDURATION] ENUM: 0=OFF 1=MIN5 2=MIN10 3=MIN15
I'd be curious as to how they are currently set?
Old Dec 23, 2020 | 02:35 PM
Rjacks258's Avatar
Rjacks258
Idk what’s wrong with y’alls trucks, or mine I guess, but I literally just started mine 5 times in a row. Start stop start stop. All within 20-25 seconds. Started every time.
Old Dec 23, 2020 | 02:45 PM
JayCarver's Avatar
JayCarver
Maybe it’s a total run time thing?
Old Dec 23, 2020 | 02:48 PM
Slowjoe6969
I am suspecting that myself. I disabled the max 30 minute idle
time in the gauge cluster this morning and will see if that makes a difference.
Old Dec 23, 2020 | 03:29 PM
Rjacks258's Avatar
Rjacks258
Wouldn’t think that, there are mornings where I start it and end up being home a little longer and end up starting it after each time out 2-3 times after the first one. I have my timer set to 15 minutes. So that’s 45-60 min back to back run time.
Old Dec 23, 2020 | 03:36 PM
LDH707's Avatar
LDH707
I have a question along these lines too. When you use the remote start do the glow plugs go hot? I ask because there is no delay whatsoever when I command the key fob she just instantly fires up regardless of temp.
Old Dec 23, 2020 | 03:50 PM
Rjacks258's Avatar
Rjacks258
Mine’s gas.
Old Dec 23, 2020 | 03:52 PM
LDH707's Avatar
LDH707
Mine’s gas.
Yea... I'm still new way new here and didn't think that out all the way before jumping in the thread.
Old Dec 23, 2020 | 04:57 PM
Crotchety Ford truck only's Avatar
"20" gas remote set to max (15 min.) start as many times consec. as I want.
Old Dec 23, 2020 | 06:45 PM
cpobst's Avatar
cpobst
Just curious why you need it to idle more than 30 minutes? I don't have it so I'm just trying to understand.
Old Dec 23, 2020 | 06:49 PM
Sometimes you don't get out of the house when you planned initially, so that's when I hit it again as it will cool off fast. My buddy who is joined @ my hip gets cold easy, the extra hit is mostly for her.
