How much lift?
Old Oct 24, 2003 | 04:06 PM
bigwheelin's Avatar
bigwheelin
How much lift?
How much vavle lift can I run with stock springs? Also does anybody know the seat pressure/
Thanks
Bob
Old Oct 24, 2003 | 07:39 PM
Silver Streak's Avatar
Silver Streak
If the stock springs have many miles on them you need new ones to increase lift. They will probably measure OK, but fatigue will keep them from performing like they should. Valvesprings are cheap, no sense taking an unnecessary risk. Also, if you have an EFI engine measure the clearance between the valve spring retainer and valveguide. On mine they are very close. I think I measured a clearance of 0.460 on mine, which is just enough to safely run about 0.430 lift. Blueprint stock lift is 0.398, but this can vary by 0.020 or so from valve to valve.
Old Oct 25, 2003 | 01:27 AM
bigwheelin's Avatar
bigwheelin
Thanks Silver Streak. I think I'm gonna need new springs
