Rear Wheel Well Liners
Old Dec 22, 2020 | 06:47 PM
  #31
303F250's Avatar
303F250
Originally Posted by 303F250
I just recently traded in my F150 for a 2020 F250. I put the Husky's on my F150 and they worked quite well (also installed them on my 07 F150 prior), so ordered a set for my F250, but haven't installed them yet but assume the quality and fit is the same as the others.
I attempted the Husky's today on my F250 (2020) , but quickly packed them back up and returned them. Went to my local Ford dealership and got the OEM ones, it took literally 10 minutes to install both sides. A little more expensive than the Husky's but worth it in ease of install.
Old Jan 5, 2021 | 06:43 PM
  #32
Jlotze's Avatar
Jlotze
Since according to the above posts that Penta makes the liners for Ford, I decided to order the Penta liners from Advanced Auto using the Christmas 25% off coupon for $85.00 shipped. BTW they list them only fitting up to 2019 models but according to Penta's website it is the same part # for 2020's.I received them yesterday and installed today. Everything went pretty smooth once I realized that I had to remove the mud flaps that I had previously installed first. It took less than an hour to install even without removing the tires. I really like the results and recommend them as a worthwhile investment!
Old Jan 5, 2021 | 06:58 PM
  #33
scraprat's Avatar
scraprat
Top Answer: 5
Good to hear. I think rear wheel well liners are worth investing in.
Old Jan 5, 2021 | 07:24 PM
  #34
4wd6.7L's Avatar
4wd6.7L
That is the way to go. Save a good amount on the same oem part.
There was a slight change in the rear liners starting on the 2020 models. Im thinking Penda made the change but kept the same part #. Do yours look like the photo bellow? Prior to 2020 they did not have that notch, for lack of a better word, it just went straight across.
Old Jan 5, 2021 | 09:08 PM
  #35
Jlotze's Avatar
Jlotze
No, mine do not have the notch. What is that for?
Old Jan 5, 2021 | 09:16 PM
  #36
4wd6.7L's Avatar
4wd6.7L
Honestly I'm not sure. I think some air bags mount in that location and on the liners that go straight across it required cutting. As far as I know that notch started on the 2020 liners. I was assuming that Penda would have just transitioned to the newer style entirely but I guess not. The only other reason I can think of would be if you got new old stock.
Penda does manufacture the liners, as you probably noticed they include Ford branded instructions. I ordered front liners through my dealer, they had a shipping label from Penda.
Old Jan 5, 2021 | 09:57 PM
  #37
HAP Const's Avatar
HAP Const
I bought some no name set off Amazon and it was a huge mistake. They were about 1/2” short of reaching the fender. Instead of snapping in the fender, they hung down. They looked so bad. I took them off and ordered Husky’s. They fit perfect. Nice and tight.
Old Jan 5, 2021 | 10:32 PM
  #38
Desert Moto's Avatar
Desert Moto
At work we have a 2020 F450 DRW and my F250 SRW, the shop ordered some Rough Country liners and I ordered the Pendaform liners. We did a side by side comparison and the Rough Country ones are going back tomorrow. Quality of the material looks and feels better on the Penda's. Also, the lower sections are wider on the Penda's, the Rough Country tapers down and follows the inner support panel, thus not providing additional coverage.
Thanks for the advice on the forum, but I am giving the Penda's the win, they are only a few bucks more if you look around. Time will tell for certain.
Old Jan 6, 2021 | 06:16 AM
  #39
Jlotze's Avatar
Jlotze
There was a production sticker on one side that was marked 9/19 so I assume it is old stock. I'll keep an eye on them to see if it ever hits the springs. I would have to be really loaded down to even come close. Thanks for the heads up though.
Old Jan 6, 2021 | 09:51 AM
  #40
Brother_Bluto's Avatar
Brother_Bluto
Penda makes the liners for Ford. Save some money and go with Penda. I bought through Autozone I think it was with 25% off coupon.
Old Jan 6, 2021 | 10:11 AM
  #41
gdru's Avatar
gdru
I got the OEM liners for the rear from Fairway Ford in Ohio. I like the look of the black wheel wells on my red truck. I am considering getting the fronts.
Old Jan 6, 2021 | 10:35 AM
  #42
Kidder69's Avatar
Kidder69
I just bought a set using the 25% off coupon at Advance Auto. Coupon code is COUPON25.
https://shop.advanceautoparts.com/p/...hTerm=7010270x
Old Jan 6, 2021 | 10:38 AM
  #43
winglesss's Avatar
winglesss
Added front and rear to configuration for $325.
Old Jan 6, 2021 | 10:52 AM
  #44
4wd6.7L's Avatar
4wd6.7L
Its not an issue with the factory springs, the liner you have is what the factory liner was for all of 17-19. The 2020 suspension is mostly unchanged.
What I was referring to was that some aftermarket air bags mount to the frame in that area of that notch, and would require cutting some of the liner to mount them. Thats the only reason I can think of for why they made that change.
Old Jan 6, 2021 | 11:59 AM
  #45
Kenny Bania's Avatar
Kenny Bania
Just ordered these rears for my 2021 XLT on order. As indicated above, Advance Auto warns you the Penda liners will not fit anything other than 2017. Will presume that is not accurate.
26% off and free shipping is probably as good as I can do.
