Need some help
2001 f350 5.4 71,xxx miles
has a misfire on cyl 2 and 5
showing -20 -40 fluctuating
increase in rpm it smooths out
has 8 new plugs, coils and injectors
compression test was right around 150 psi x8
leak down held 100% ( actually pushed piston down)
fuel pressure is about 38 psi
valve springs in tact
cam lobes in tact
Almost sounds like an injector issue. You could maybe try swapping injectors from a good cylinder to missing cylinder, and see if the issue follows the injector or stays with the cylinder.
