There is a junk yard near my work that had an EX in it. I might be able to grab some parts for you if they have what you need. It was a V10 truck. Which motor do you have?
I have an 04 with a 6.0. The parts I need should not be motor specific. I need the airbox on the firewall which holds the evaporator and accumulator but I do not need either of those parts. The sensor on the front is the difference between superdutys and excursions. The Ex has a larger sensor. I also need the AC lines which go to the rear AC. I only need the rubber hose parts under the hood and the hard lines back to at least the front passenger door.
if you can help that would be great.
thanks,
Jeff
After Christmas I can swing by the junk yard and see if those parts are still there and the cost.
I am in Maryland so shipping might be a little pricey. I will let you know what they have and the cost once I get a chance to stop by.
Edit: you may want to reach out to member @Nicmike he is in Texas and seems to have a junkyard he goes to that is a goldmine of parts.
Mike, yes, I need part of the long AC lines. What I need is the rubber hose ends in the engine compartment with the hard ends attached but I only need the long pieces back to the front passenger door.
Ok. Hass at hitechcarparts.com here in Buda should still have the full set I pulled from an Excursion they had in the yard. You would need to call to confirm he still has them. I also pulled the full rear unit for them. They had it on the shelf last time I was there, but a lot changed for them in the last year.
