Anyone hear when the superduty will see a new interior? Seems like I heard 2023 but wondering why they would wait if the f150 already has there’s and they share a common cab. I would probably wait to order if I knew I could get a 22 with a new interior.
Anyone that gives you a firm answer is just guessing. Currently the best guess is 2023. Just because they share a cab layout ( Cabs do not interchange) doesn't mean the components are directly shared. The F150 uses more modules and some features are dependent on F150 only standard equipment that isn't used in the Superduty.
Do they actually share the same cab as of right now?
If the last gen was any indication, the new body/interior F150 was out in MY 2015 and the Super Duty didn't change over until MY 2017. So 2023 might be a good guess.
Expect the new Expedition refresh to usher in a vastly new interior that won't be shared with the new SD interior as it is now. The new SD interior will be mostly the 2021 150 interior. Coming summer 2022 along with the usual exterior and powertrain updates.
Yes, they do but, different interiors which right now has nothing to do with the actual cab.
The actual cabs are not shared, while they are similar they are not the same cabs. With that said most components do swap. The rear of the cabs and the firewall are both very different for their respective chassis.
Dont know about the whole cab but the doors are interchangeable because I put an f250 door on an F150 before. You will need some stuff off the f150 door and vice versa so don’t throw the junk away too quick.
Talking 2021 F150 and 17-21 Super Duty....I think. It is sounding like maybe the posts above are saying the cab is not new for the 2021 F150.
