Dual Tank Issue
Old Oct 29, 2000 | 07:21 AM
DannyP's Avatar
DannyP
Dual Tank Issue
Old Nov 19, 2000 | 04:34 AM
tundrakat's Avatar
tundrakat
Dual Tank Issue
I recently purchased a 1990 Ford F250 4x4. I noticed, when I was looking at it, the dual tanks. The salesman on this corner car lot didn't know much about the rig. Anyhow, after I picked it up, I tested the dual tank switch and it showed a half tank reading for the rear tank and empty on the front one. I filled the rear tank and the fuel guage show that it was full. I attempted to fill the front tank but it was already full, but the guage says empty when switched over. I let run for a bit on the front (empty reading) tank and the truck kept running. I am puzzled...
Old Nov 19, 2000 | 05:30 AM
walterdanek's Avatar
walterdanek
Dual Tank Issue
Sounds like a bad ground wire or float gauge in the tank
Walter
Old Nov 19, 2000 | 07:53 AM
DeenHylton's Avatar
DeenHylton
Dual Tank Issue
Walter is on the right track. If you read many posts on this board you will find that it is not uncommon for this to happen. My 1989 F250 does the same thing. It is more likely to be a bad ground wire or loose/corroded conection than the in-tank float. Deen
