If you open the hood and stand by the driverside fender looking in ,look by the where the lower coolant hose from the radiator goes to the engine block .the hose passes right by the steering box and goes to a water manifold mounted to the block .The oil sender is just to the right of this connection .Its real hard to see and not alot of room down there .You can reference the oil filter and the oil cooler lines to the right and behind the motor mount.
