error codes 32(m) and 41(r)
Old Nov 20, 2000 | 08:02 AM
bjoern's Avatar
bjoern
The check eingine light on my 1988 302 5.0l EFI F-150 is flashing during accelleration, so I pulled the codes and came up with 32 (EVP/EGR related) in memory and 41 (running lean) while running.
I guess I should check for a vaccum leak or a faulty EGR valve to get rid of the 32 error, but how about the 41? The O2 sensor is new, so it can't be that. But I had to put on new headers as one of the exhaust manifolds was broken. Could it be that the headers are leaking? If so, how can I find out?
Old Nov 20, 2000 | 05:05 PM
cgl's Avatar
cgl
I'm not sure about the 41. I had a 44 and fixed it by replacing the Vacuum lines (one main going back, two small ones coming forward) But I did have the 32 error, and to fix it, I replaced the EVP Sensor. I believe it should cost around $32 or so. After I replaced it, the Check Engine Light never came back on, and the EEC isn't producing any more codes. Just make sure you get the right colored Sensor.
Old Nov 20, 2000 | 07:14 PM
KTMNealio's Avatar
KTMNealio
