Hey guys I have a 2018 f-250 and my trans peaks around 230 when I’m towing a 14k trailer up huge grades and the drops, my question is will this wreck or shorten the life on my truck and when should I change the tranny fluid? Are other people running similiar to me?
thanks in advance
The key to keeping trans temps down is to manually shift the transmission to a low enough gear where the rpms are high enough to pull good, and most importantly, keep the torque converter locked. An unlocked torque converter will raise trans temps a lot in a short amount of time.
This is key right here and the main reason I tuned my 6.2 my converter is fully locked from 2nd gear through 6th in towhaul and 3rd through 6th in normal mode. Ford has them lock up I believe 5 Star told me in only 4-6 and only 60% of the time they never fully stay locked up. 5 Star made my 6.2 like driving a totally different truck. After driving it tuned for over a year now I loaded the stock tune back up just to see the difference and man did it suck I got back from town and put my daily tow tune back on it.
I see transmission temperatures in the low 230's in my F-350 when towing up mountain passes and towing my 11K GVWR travel trailer.
I tried forcing the transmission down a gear or two, but I didn't see enough of a change in the transmission temperature to justify manually shifting the engine. On my prior 1/2 ton truck that was a very common and very effective thing to do. I thought I would see a similar effect on my F-350, but it didn't happen. Maybe it was just that instance. I'll try it again eventually.
