rear end
Old Dec 11, 2020 | 03:54 PM
fordfun55's Avatar
fordfun55
rear end
will the rear end,springs,carrior etc fit from a 1955 ford mainline into a 1955 f100. My truck has 3.92 rear gears and was wondering if 1955 car would possible be more streetable
Old Dec 11, 2020 | 04:55 PM
38 coupe's Avatar
38 coupe
No, the assemblies don't swap. IF the mainline is a station wagon or sedan delivery there is a chance the gears will swap, but then probably wouldn't be any higher speed than the ones already in your truck.
Do you have three-on-the-tree? If so, have you considered an overdrive transmission? That is much easier to put together, and fun to drive.
Old Dec 11, 2020 | 05:48 PM
1956_F100's Avatar
1956_F100
Since it seems you don't mind keeping a Dana 44 rear axle in it, why not just get the parts to rebuild yours and change the gear ratio? Parts are readily available for it. I found Rock Auto to be the least expensive for the same brand names others were selling when I rebuilt my Dana 44. When done, the truck will still have it's original rear axle which is a good thing.
busted 55
Aug 5, 2014 01:23 AM
driver96er
Mar 4, 2008 04:09 PM
hernando
Feb 9, 2002 02:30 PM
jaye
Jan 3, 2001 04:11 PM
