Forscan
Old Dec 10, 2020 | 12:14 PM
alberta46's Avatar
alberta46
Forscan
Will changes made with forscan void warranty?
Old Dec 10, 2020 | 12:53 PM
ford390gashog's Avatar
ford390gashog
Forscan doesn't have PCM access, that's the only thing Ford looks at. But it is a modification none the less so do assume the risk if you don't make a recovery file of each module and brick one.
PupnDuck's Avatar
PupnDuck
It would depend on WHAT you change. And Mother Ford will know!
Old Dec 10, 2020 | 01:07 PM
ford390gashog
Only module with a rolling hexadecimal check digit is the PCM. There is no trace on the other modules.
Lubbockguy1979
Jan 28, 2010 04:24 PM
touting
Oct 27, 2006 10:33 AM
Saxon
Car/truck Buying Advice
Sep 13, 2004 03:42 PM
"Luke" SdeS
Mar 12, 2004 02:57 PM
