RV Wi-Fi Extender
Old Dec 7, 2020 | 04:10 PM
kehinnc's Avatar
kehinnc
RV Wi-Fi Extender
Has anyone used a Wi-Fi Extender in their RV while at an RV Campground? Looking for recommendations.
Thanks
Old Dec 8, 2020 | 01:28 PM
RA12726's Avatar
RA12726
Banned
Increasing the signal strength on what, in most cases, is poor wi-fi, is just making bad stronger. Most campgrounds do not have good bandwidth which makes streaming or any other data-intensive activities iffy at best. We've stayed in a number of campgrounds which, on their check-in paperwork, state that the park wi-fi is only for checking email and reading the news.
If you want some in-depth information, you can research here:
rvmobileinternet.com
Rob
Old Dec 8, 2020 | 02:38 PM
HRTKD's Avatar
HRTKD
I've been at two campgrounds where my camping spot had a lousy signal to the Wi-Fi and getting email was a challenge. I walked around and found the Wi-Fi antenna and stood next to it. Throughput still sucked, like it was connected through dial-up modem.
Old Dec 8, 2020 | 03:40 PM
camping nut's Avatar
camping nut
If it is just for picking up a signal we have the Winegard connect 2.0 and it is great for picking up a distant/weak signal. But a little bit more then what you are looking for.
Old Dec 17, 2020 | 03:37 PM
Byrd.Dog's Avatar
Byrd.Dog
I would suggest wireless radio, like a Ubiquiti NanoStation: https://www.ui.com/airmax/nanostationm/ paired with a small WiFi access point to keep in your camper(a cheap wireless router from Walmart will work if it has a "Wireless Access Point" mode). This allows you to connect to the park wireless with a radio that's a lot more powerful than the one in your laptop or phone. If you'd like suggestions on specific equipment, let me know; I do this for a living.
Old Dec 17, 2020 | 05:23 PM
djousma's Avatar
djousma
Agreed on most CG wifi less than useful. The last thing the CG operator wants is all their campers streaming Netflix on their dime. You are better off investing in a good 4G cell amplifier and using your phone as a hotspot. I am an IT guy, and worked this past year this way with no problems.
Old Dec 17, 2020 | 06:30 PM
matt167's Avatar
matt167
My home internet is similar to what is needed here. I use a cheap phone with Visible as the carrier ( $40/ unlimited including hotspot ), I broadcast the phones hotspot and have a TP Link WISP router pick it up and re broadcast it securely on a seperate network.. I think the router cost $20 on Ebay brand new.. A WISP router is what you would want as for one it's secure, but second your signal to your phone or device will be stronger.. The WISP router, you just give it an SSID and password and away you go
JimG1098
Sep 23, 2020 07:58 AM
montrese04
Jul 14, 2017 02:18 PM
sierraben
Jun 23, 2015 10:52 PM
wulfman
Dec 7, 2010 02:43 PM
airmanline
1997 - 2003 F150
Mar 1, 2010 08:26 PM
