Aerostar Ford Aerostar
ENGINE red warning light
Old Oct 24, 2003 | 06:47 AM
NorthernStar's Avatar
NorthernStar
I am getting the red warning light "ENGINE" , second-top left, Analog dash, 1989 3,0l. I have asked around, checked the "Haynes"-book and manual with no exact answer.
What does it indicate? Should I not drive it at all?
The thing is- I am trying to get rid of a "check engine"-condition.
I had a shop do a tune-up; plugs, cables, fuel filter, distr cap.
Found no vacuum leaks.
That did help.....for about half a day.
Then I cleaned the IAC, added injector cleaner to the fuel and made sure all air was out of the cooling system. Helped a lot!
Then the heater core went down causing loss of coolant and rough running and erratic shifting plus more "check engine".
Changed heater core, O2 sens, changed autom. fluid and filter, filled up coolant and still have the "check engine" and slight misses when picking up speed slowly.
Fully synthetic oil, -still clear, exhaust fumes seem normal, -no white fog, no black smoke.
And now the "ENGINE" light on top of that.
Please help!
I simply assume u experts out there will figure this one out in no time!
Old Oct 24, 2003 | 07:18 AM
90XLT_Silver_Bullet's Avatar
90XLT_Silver_Bullet
from what my friend has told me, it is the o2 sensor on the exhaust pipe, its nothing, no worries
Old Oct 24, 2003 | 12:15 PM
87 XLT's Avatar
87 XLT
Pull the codes again and post them here.
Old Oct 24, 2003 | 12:36 PM
aerocolorado's Avatar
aerocolorado
Do you notice any flucuation in the oil pressure gauge? If so, you may have failing oil pressure sending unit or the wire/connector is corroded or dirty. Look for the sending unit on the passenger rear side of the engine and see if the connection appears in good shape. It is a single wire connector.
Old Oct 27, 2003 | 03:02 AM
NorthernStar
Thanx for the responses, all!
I haven't pulled the codes yet. Seems only one shop (Ford dealer) have the gear. I will have it done asap.
Oil pressure reads stable, but a little low, perhaps. Will check unit.
Will also check if there's exhaust fumes in coolant, as I'm beginning to suspect a leaking head gasket... Wish me luck.
Old Nov 1, 2003 | 08:46 AM
NorthernStar
My hat off to you all.
My van runs like new thanks to the Forum,
.... one new battery and two rounds of injector cleaner.
I was close to selling the thing, but thanks to the optimism of the forum, I kept on trying different tricks,- and now it works!
