Sponsored by: Real Truck
Difference between front and rear rotor?
Old Dec 7, 2020 | 10:47 PM
queen of spades's Avatar
queen of spades
@PJWhelan, brake jobs are good to learn how to do.
With big trucks like these it's never a bad idea to replace all components at once (front and rear rotors, calipers and pads) if you find you need to replace any of the calipers, especially if you find yourself towing equipment or heavy trailers frequently. If you live up north you may also take the time to inspect your brake lines for rust and corrosion. At a bare minimum, be sure to get new rotors and pads if you can't swing getting new calipers on every wheel. Summit has a good caliper kit that includes the brackets so all you do is put new pads in and bolt them on.
There are a ton of how to videos on youtube for replacing calipers and rotors on the 99-04 Super Duty trucks.
Old Dec 7, 2020 | 10:53 PM
queen of spades
Front caliper set:
https://www.summitracing.com/parts/p...250-super-duty
$143.99
Rear caliper set:
$111.99
Four rotors with pads:
https://www.summitracing.com/parts/p...duty/year/2002
$371.99
You'll want at least two 32oz bottles of DOT 3 or DOT 4 brake fluid on hand. I usually have four of those 32oz bottles just in case.
You'll also want to look at youtube videos on bleeding brakes - you may find it hard to do without a helper to sit in the truck and press the brake pedal - the videos will explain how that works.
strokenboost
Aug 10, 2016 12:34 PM
mmenzies
Jun 4, 2013 03:31 PM
mwrohde
Jun 14, 2012 04:07 PM
Dregsz
Mar 17, 2008 09:03 PM
cangim
Feb 22, 2006 08:34 AM
