Cummins to a Ford thread near you!
#76
I don't remember exactly what I used now and sent what may be incorrect info in the PM I just sent. In the following post, you can see that I used the standard Cummins SS braided lines and adapted it to the mechanical gauge (in the pictures):
https://www.ford-trucks.com/forums/1...l#post18878990.
You can see it better here and the post is more specific:
https://www.ford-trucks.com/forums/1...l#post18864340
Hope this helps!
Hope this helps!
The following users liked this post:
#77
Debating on using the OEM Cummins lock washer on the p-pump vs. the special Nord-lock one from DAP Diesel.
Seth supplied an OEM lock washer and said 175ft lbs. I already had both a new Cummins OEM washer as well as the Nord-lock washer from DAP.
Sure looks like the Nord-lock is the best option to avoid that pump slipping. DAP says to apply 146 ft lbs with the Nord-lock (similar to OEM torque specs).
#78
#79
I don't....and that may be a tough one to find. I did find this, which may get you there:
https://sleequipment.com/cummins-gen...et-sensor.html
I've not ordered from them and haven't even heard of them. Another source might be Crazy Carl. He may at least know where to get one. I will say I messaged him on FB a few weeks ago and he hasn't responded.
#80
#81
#82
That piece may not be necessary. Unless you need to run a dodge style TPS, you should be able to just leave that part off.
Are you planning on using the dodge style TPS?
#83
Thanks Antonm!
#84
#85
Would this part suffice? Not the same part number (maybe an update revision or something), but it seems like it would hold the TPS.
https://puredieselpower.com/dodge-pr...r-bracket.html
#86
Looks like they even have the bolts to hold it on.
https://puredieselpower.com/dodge-pr...bracket-2.html
#87
#88
#89
Looks like that parts has been discontinued. Scroll all the way to the bottom of the description in the link below. Says "TPS Bracket (not shown) - 3931556 Discontinued). Looks like used is gonna be your only option. Maybe give some pump rebuilders (like Seth Farrell) or bosch shops a call to see if they have one off a core/ trashed pump they'd be willing to sell.
https://puredieselpower.com/dodge-pr...nkage-kit.html
#90
Thanks for looking though Antonm
