Cummins to a Ford thread near you!
#32
#33
The linkage rods are a different set of part numbers. This is specifically from a 1995 12 valve Cummins with a manual transmission coming out of a Dodge.
Highly recommend if you need more than one of the parts, that you scour junkyards for a donor assembly due to costs. Oh, and replace the stock bushings with brass immediately assuming the bellcrank shaft is worth saving.
#34
Do you have a picture of the additional bracket?
#35
Bellcrank lever assembly if revised part number 3931560 and the main bracket assembly is part number 3931559.
#36
When I worked on Heavy Equipment all the Cummins engines in the Equipment were a Black color, rebuilt Cummins Engines were tan whenever I replaced a existing engine.
#37
Why does it matter what color it is? Needing post counts?
#38
#40
I myself like the neutral color like you used, the last engine I prepped for a guy he wanted it Gray. I've seen red and florescent green engines, I don't care for that color but if that's what they like good for them.
By the way nice build you have going on and thanks for the info. I'm sure there have been people that didn't like something I did in one of my Conversions but it's my Conversion. Just like your building yours the way you want it so that it's your touch. No offense taken.
#41
https://powerdrivendiesel.com/produc...crank-bushing/
I have the set I bought OEM (from Geno's part# 4425053) if you need a pair of the nylon ones. I test fit them on my original bellcrank shaft and decided the shaft was too worn and would eat them.
After I found my bellcrank shaft was shagged, I decided to get that new bellcrank lever assembly and went with brass so it never happens again.
#42
#43
#44
That's the part from Mike Fuchs that lets me use the Ford V10 alternator and AC. Apparently guys use a 6 rib belt, but I'm going to swap the two pulleys out to 8 rib. I'll still have to probably replace my AC lines due to age but might not need to have their length adjusted. I have a one wire alt already set up to go if I need to as a backup plan. I just thought it would make it easier if I needed a roadside repair and was out of town. More pics tonight probably as I plan on dropping the head on it and putting it on the stand for final torque pass.
#45
