Engine Cross Member or Rail
Old Dec 5, 2020 | 10:15 AM
J2Davis's Avatar
J2Davis
55 F100, coil over IFS. A vender asked me what the distance was between my frame rails. When I told him he recommended putting in an engine cross member. The crossmember would sit just behind the IFS so I'm not certain that it would add any structural benefit. I know that some will cringe when I share this but I was given an LQ4 and 4L80e so am installing that. Is there a frame rail span that if exceeded makes it difficult for a frame mount tower and engine mounts to properly support the engine, and forces generated by the engine? Would a crossmember provide any benefits versus rail mount towers as far as headers and steering shaft?
Thanks
Jerry
Old Dec 5, 2020 | 12:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Doesn't your IFS have its own crossmember?
Old Dec 5, 2020 | 12:46 PM
1956_F100's Avatar
1956_F100
That is my question as well. Plus, is the original transmission crossmember still installed? That one is a major structural component. Many remove it because some transmissions simply will not fit. But in my opinion, if it's removed, some other type of crossmember needs to be installed near where that original trans crossmember was. Without it, the weight of the cab on the front cab mount wings can potentially twist the frame rails.
Old Dec 5, 2020 | 01:06 PM
52 Merc's Avatar
52 Merc
Typically, an engine mount crossmember and an IFS crossmember will want to occupy the same space. That usually doesn't work too well and a plan B is required.
Old Dec 6, 2020 | 10:41 AM
J2Davis's Avatar
J2Davis
Thanks guys! I am pretty certain that I do not need another cross member. Yes the installed coil over IFS has it's own crossmember so I am on to plan B. I have not removed the stock transmission crossmember but I suspect that I will need to replace it. I am guessing that maybe the engine mount towers will be mounted directly on the IFS crossmember or the rails. Thanks
Jerry
Old Dec 6, 2020 | 11:02 AM
Waygonner's Avatar
Waygonner
I have mustang ii setup from tci and am installing Ford 390. Engine mounts weld to frame and xmember and you need to set it up with the transmission attached and trans xmember in place so you can set proper angle in relation to rear axle. It isn’t really plug and play but you don’t need another xmember for the engine, the ifs one is plenty.
Old Dec 6, 2020 | 04:14 PM
Cougar54's Avatar
Cougar54
I also have a TCI Mustang II front end that I am installing and an extra crossmember at the engine mounts is not necessary. That front crossmember is plenty beefy. I am removing the OEM transmission crossmember since mine was hacked up by a previous owner. I can get away with this since I will be using a firewall mount booster and master cylinder. The crossmember will be replaced with a new crossmember to support the transmission. This way I can set up the transmission crossmember at the perfect distance and the proper angle as needed.
Old Dec 6, 2020 | 04:27 PM
Old F1's Avatar
Old F1
so you can set proper angle in relation to rear axle. .
Not sure if this reverlant and please correct me if I am wrong here, but on a carb-ed engine the engine rearward angle is built into the intake manifold so the carb mounting flat should be installed level.
Old Dec 6, 2020 | 04:40 PM
Cougar54's Avatar
Cougar54
The small angles we are talking about shouldn't affect the fuel level very much in the carb and can be reset if necessary. My 302 is fuel injected so this isn't an issue for me.
Old Dec 6, 2020 | 05:16 PM
Waygonner's Avatar
Waygonner
You aren’t wrong. It would be ideal to have the carb level at ride height. I do also need to make sure my drive shaft has relative angles to the trans and rear end so I don’t eat u joints and have vibrations. I also don’t know exactly what level will be for the carb with out all of the weight of everything on there so there is a bit to figure out.
apologies for thread hijack. At the end of the day, I think we are all in agreement that you don’t need an additional engine xmember besides the ifs one.
Old Dec 7, 2020 | 08:18 PM
J2Davis's Avatar
J2Davis
Thanks again guys. I have fuel injection in mine, so I am not certain being level is as important.
Old Dec 8, 2020 | 03:47 PM
1956_F100's Avatar
1956_F100
Also, carb angle is very dependent on intake manifold. Set it up level for one intake, then change intakes and all is lost.
On another note, with fuel injection, single plane intakes work better simply because they have more equal distribution between cylinders..
Oldcrowbarber
Ford Truck Parts for Sale
Jul 30, 2017 08:58 PM
toymobile
Oct 2, 2016 03:24 PM
staysbroken
Sep 13, 2010 09:33 PM
Old_Crow
Jan 10, 2010 11:12 PM
pcmenten
22
Aug 24, 2004 07:20 AM
