I've had a lot of f150s and the I usually leave the bigger side of the rear seat up. My new 450 it falls and won't stay in the up position. Is there a way to adjust something? Seat doesn't feel loose. Thanks guys
After I installed a latch kit on my 2020 F250, my seat did the same thing. The latch wasn't closing on its counterpart mounted to the rear wall of the cab. I ended up putting some lube on the latch and that fixed it...at least temporarily. It seems the latch has too much friction to work properly without some help. hope that helps!
Is the seat padding preventing you from engaging the catch? Also the seat back comes down a little when the seat bottom is folded up... anything blocking that travel like a sub box or tools?
