2005 F-150 No Turn Signals, Brake lights or Flashers
2005 Ford F-015 5.4 crew cab. Driving to work and I put on my turn signal and it gave me the quick clicking indicating a burned out bulb. I checked all lights and all the bulbs are fine. Then I realize I have no brake lights or flashers. Youtube searches tell me it is the multiswitch in the steering column and others tell me to clear the codes to fix it. Before I spend $135 on a switch, does anyone here have any experience with this issue?
Thanks,
David
Thanks,
David
The flasher cannot cause this symptom.
The 05 has a MFS but there is no "programming" possible regarding brake lamps or turn signals. That came in later models.
I'd recommend that you check the wiring harness on the steering column to see if it's been stretched by a tilt column that has been lowered all the way.
Since it's been almost 2 months since he posted, it's likely a moot point by now anyway.
hasteranger
07-20-2012 01:34 PM
77f250400
12-13-2010 03:22 PM
cjben
Electrical Systems/Wiring
09-10-2003 05:16 PM
