Drop Hitch Length....Guessing
Headed out to Michigan to pick up a Legend Aluminum Flat Top V Enclosed Cargo 7x21. I have no idea how high the tongue rides on this thing, but it’s on 15 inch wheels.
I haven’t replaced my B&W Tow and Stow ( for sale if you need one) from my F150 but it’s the 3 inch drop 2 inch shank and I’m guessing that won’t fly.
2 questions:
1. What length drop do y’all guess? My F250 is a 3 inch Receiver truck measuring approx 19.5 inches from ground to bottom of receiver.
2. What brand ball mounts do you guys like? Seems the 2.5 inch shanks offer a lot more options at a lower price point, and I don’t foresee ever pulling close to the limit on the bumper pull.....but I didn’t foresee buying another Super Duty either, sooo.
Thanks!
Unfortunately, at the time I got the truck, I needed something quick to pull my trailer to the Tail of the Dragon. Shortly after that I pulled a 30" travel trailer. Both were level.
Now that I have time to work focus on the truck over the winter, I'm going to scrap the reduction sleeve and get a Bulletproof or Weighsafe that has ball and pintle provisions and a 2.5" shank.
I'd suggest going with a 3" shank and forget about the reduction sleeve; they rattle due to slop and will elongate the pin hole.
Thanks, no problem on the 8 inch drop with ground clearance? I did read somewhere they “lowered” the 20s.
I am going to see if I can flip it upside down and adjust my trailer and get another hitch for my F150 to match the raised trailer tounge. Or chop an inch or 2 off.
I would do a 3 inch 6 or 8 inch drop that matches your hitch which is 20k I believe (although they tag some 3 inch set ups higher). I would also find one that flips around so you can back up close to stuff.
My 10 inch fastway hitch is 2.5” and rated to 20,000/2,000. Got it incase I get a 350 and can use an adapter on it. Would probably tack weld it to the truck to avoid elongating the pin holes which can happen.
The 10 seems excessive...I am torn between 6 and 8
An adjustable height mount/hitch will provide versatility for travel trailers, lightweight trailers, and heavy duty equipment trailers (in case you decide to buy/rent one).
1. Go with an adjustable
2. Ask for the height of the trailer tongue when level
3. Get both 6 and 8 inch drops and measure when you get to the trailer; return whichever one is not appropriate..
As a very rough estimate (check my math), the trailer appears to have 205/75R15 tires. The rim radius would be 7.5 inches. Tire sidewall height is 75% of 20.5cm, which is 15.3 cm or 6.05 inches. So from center hub to tread is approx 13.5 inches. It would seem 6" is sufficient since you are measuring 19.5 from the truck to ground, but there may be a slight rise/drop from the axle mount point (presumably in the center of the frame heightwise) to the tip of the tongue.
https://legendmfginc.com/wp-content/...07/008-FTV.pdf
So far I have not needed to use the up position but I do plan on trimming about 1/4" off the hitch.
I posted pictures elsewhere on this forum, I have a problem with the locking pin for the removable ball seizing in the slider.
Link to corrosion.
https://www.ford-trucks.com/forums/1...l#post19596664
Regarding how low you need to go, I have the 10" because my EZ hauler single axle cargo trailer 15" wheels actually is that low, the 10" is what it took to tow the trailer level.
If you are pulling a single axle trailer it won't really bother the trailer if it isn't level, as the wheels and axle don't know the difference. If it is two axles then you need to be level.
Link to corrosion.
Hmm that sucks. I will have to check on my platinum tailgate this weekend.
Thanks will let you know
I measured today the distance of 10" from the pavement to the bottom of the shaft.
My 2020 F-250 STX CCSB has the 6.2 L, 4x4, stock suspension and 275/70R18 OEM tires.
The bulletproof also seems like a quality hitch that is rated for higher than I will ever tow.
I recently purchased a low profile dump trailer and even with the adjustable tongue adjusted as high as possible it is a little nose high. The couple times I have towed it, I just put a little extra weight in the front to settle it down and make it level.
I would like the additional adjustment the 8" offers, but I don't want it dragging. My truck is basically stock height, although I put a slightly bigger tire on it (285/65/20 in the summer and 285/75/18 winter)
I will be watching this post for recommendations.
