Caster Angle
Old Nov 27, 2020 | 04:56 PM
Tristian Knutson's Avatar
Tristian Knutson
Caster Angle
I swapped a Dana 44 kingpin and Dana 60 under my 64f100 and converted it to 4WD with a 205
been fixing driveshaft angles along this project but I haven’t been able to find any good info on caster. The axels came from a 74f250 highboy. I know caster is supposed to be between 3.5-4.5 positive( upper kingpin aft of the lower kingpin). But I can’t find a place to get an accurate measurement. So does anyone know where to measure from? Or the relationship between the pinion and caster?
thanks in advance!
Old Nov 28, 2020 | 11:53 AM
FuzzFace2's Avatar
FuzzFace2
On a 4x4 front axle they are what they are as they cant be changed from what I have ever seen.
Did you cut the spring mounts off the axle and weld on new ones?
Did you measure between the spring mounts and the pinion face to see what this was?
If you had the pinion face 90* to the floor then dropped a plumb bob down the kingpins or ball joints and measured the difference that would be the caster angle no?
To change this you would use shims between the springs and the axle to rotate it just like to change the pinion angle.
If the axle was level could you drop the bob along the hub face to measure the camber?
Again I don't think either could be changes as it is built into the axle.
Dave ----
Caveman2851
Jul 27, 2018 09:00 AM
mark a.
Offroad & 4x4
Nov 23, 2008 10:49 AM
piperig78
Jan 19, 2006 06:09 PM
Slow
Sep 25, 2005 01:32 AM
