OBDII not working
Old Nov 25, 2020 | 01:15 PM
Whiplash2130's Avatar
Whiplash2130
OBDII not working
Why would my OBD II quit working after three years using my OBDLINK MX adapter without issues?
Old Nov 25, 2020 | 01:33 PM
grumblin's Avatar
grumblin
so nothing you plug into the OBD II port works? Did you check the OBD fuse?
Old Nov 25, 2020 | 01:51 PM
Whiplash2130
I tried a new OBD adapter, same result. What fuse? Is there one inside the adapter?
Old Nov 25, 2020 | 02:12 PM
grumblin's Avatar
grumblin
There is a fuse for the OBD controller. Check your manual for the exact location.
Old Nov 25, 2020 | 02:15 PM
Whiplash2130
Will do... Thanks
Old Nov 27, 2020 | 11:46 AM
Whiplash2130
The manual says it’s fuse #15 smart communication data 10A in the passenger compartment just left of the steering column. There is no panel at that location. There is however a fuse panel behind the kick panel on the passenger side just forward of the door. The fuse in location #15 at that location had a micro3 10A fuse which had one leg burnt. Replacing it fixed the whole problem. Thanks for the assist!
Old Nov 27, 2020 | 08:35 PM
grumblin's Avatar
grumblin
Excellent! Happy you found it.
Brian429
2015 - 2020 F150
Oct 20, 2019 07:39 PM
johnnich33
May 22, 2019 03:20 PM
roc2178
Sep 23, 2012 08:44 PM
Fordfanz
West Virginia Chapter
Nov 30, 2004 10:21 PM
