Wife has the 20" wheels with the chrome lugnuts. They are starting to get deformed a bit and on the last rotation I had to beat the socket on 5-6 of them. What are some good quality replacement lugnuts?
Gorilla has what you’re looking for and is the most popular option.
Also, Costco offers replacements for the F150 lug nuts that are prone to swelling up and failing.
I put Gorilla on mine.
They started rusting after 6 months.
Gorilla sent replacements that I have not used.
What Ill probably do is go back to the original SS ones.
Then change them back to Gorillas when someone else is likely to work on the tire.
I can get the 5 or 6 I need fairly cheap.
* If you are careful and make sure you get the socket all the way on the originals, they are fine.
The issue starts when the socket is not put all the way on.
The actual "lug nut" under the stainless cap is slightly tapered.
I'd look around the dismantelers and try to find some OEM's... All of the replacement lug nuts I have bought new were from China and made of very soft metal. Use lots of never-seize on them.
That's what happened to me. The fit is extremely tight and I didn't have the socket on as far as I thought and messed the ends up. Pounding the socket on with a hammer got them to work but they need to be replaced the next time they come off. I might just look into the OEM replacements form Rock Auto since the rest of them are good.
ETA. Looked on fordpartsgiant.com and I can get OEM lugnuts for $3.41/shipped.
Changed mine on the Fusion to solid stainless steel. If you live where they salt the roads it penetrates between the plating and the nut and swells. Will do the same with the 2020 F-150 when it happens. @#$%^&*() Ford for not putting solid stainless on them as OEM.
No manufacturer will use solid stainless steel as standard equipment.
Hobo
OEM lug nuts are a two piece design and they fail hence the reason for swapping them out for an aftermarket one piece design.
