Downshifting VS neutral braking?
Old Nov 23, 2020 | 08:39 AM
96 OBS's Avatar
96 OBS
Thought I’d throw this up for discussion since there’s so many opinions about it. What do you 5 speed guys prefer normally? For stopping do you throw it in neutral and just brake? Or do you downshift with clutch or float to downshift? Just curious I normally put it in neutral and just use brakes because I feel like every little bit of stress I can save the clutch might be worth it
Old Nov 23, 2020 | 09:17 AM
farmert's Avatar
farmert
Normally I let the backpressure from the engine slow the truck. If the truck is not slowing quickly enough, I apply the brakes while it is still in gear, down shifting when the RPMs get low enough for the lower gear.
Old Nov 23, 2020 | 09:33 AM
MJ79's Avatar
MJ79
I do the same as farmert. Slows down pretty good with the motor. My clutch is well past the baby it stage lol.
Old Nov 23, 2020 | 10:32 AM
JayTheCPA's Avatar
JayTheCPA
Why is this a question for just hand shakers?
I downshift with slushboxes too.
I can live with sitting at a stoplight, a blown tranny, and motor just spinning. Am not so sure about blown brakes.
Old Nov 23, 2020 | 10:37 AM
FinnishStroker's Avatar
FinnishStroker
Downshifting with gears and braking as well ,with common sense..Handling not so good in neutral and saves the brakes.Bigger the rig=more engine braking.
Old Nov 23, 2020 | 10:53 AM
JayTheCPA's Avatar
JayTheCPA
There is also a second order benefit of downshifting: better fuel economy. While some will argue that shifting into neutral is better for fuel economy, I have found that letting weight push the motor more is beneficial to fuel consumption compared to coasting in neutral. Especially if the computer senses the situation and de-fuels. By shifting into neutral, the motor will still burn idle fuel to keep it from stalling.
Third order effect of not shifting into neutral is (as FinnisStroker touches on) that there is commonly a lag in getting back into power. By staying in gear, I can instantly apply power if necessary.
With a stick, the only scenario I do not downshift is if I have to brake suddenly and there is not enough time to work all the pedals. Put another way, when shifting I rev-match / float rather than let the clutch absorb the RPM differences. If I have to stop quickly, it is a bit hard to toe-heel with the pickup's pedal configuration, so I just go for the brakes and disengage the clutch.
Old Nov 23, 2020 | 01:16 PM
96 OBS's Avatar
96 OBS
Normally if I downshift I rev match as well. Way I see it is a brake job is probably half price of a clutch. Enjoying the inputs tho y’all have some good advice
Old Nov 23, 2020 | 01:27 PM
Hit Man X's Avatar
Hit Man X
I just slow down like others. Unless around 1000rpm then clutch in and watch traffic. Total stop goes to neutral...slow roll depends on speed, but 10mph and a quick throttle blip and back into 3rd for me. That is my tire height/trans ratios/axle ratio.
Constant downshifting is harder on the clutch assembly per South Bend and more wear on those syncronizer rings.
Old Nov 24, 2020 | 09:27 AM
oldbird1965's Avatar
oldbird1965
With my heavy 5er I use a combination of both, common sense approach! On some downhills in mountain grade territory if you don't downshift you will end up with 'no brakes'!
Old Nov 24, 2020 | 12:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Glenn, how do you downshift with an automatic trans?. It is good idea to install a exhaust brake.
Old Nov 24, 2020 | 02:14 PM
knottyrope's Avatar
knottyrope
I run through the gears unless its a panic stop, then i toss in second in case rear brakes lock up and pop clutch if needed.
my 99 taco 2.7 I4 still had oem clutch in it after 180k miles and i wasnt easy on it
Old Nov 24, 2020 | 09:24 PM
paddler's Avatar
paddler
Slightly different opinion, from an E4OD driver who usually is lightly loaded. I'm not looking to get more long life out of the brakes. Pads and shoes are much cheaper than transmission or clutch, so I prefer to put the long-term wear on the brakes. Where I will downshift with the auto- turning off OD or downshifting into 2nd with the selector- is a steep or long grade where I don't want to overheat the brakes on that grade, lose brakes, and have a run-away right then and there. I'll use the engine and transmission to help keep the brakes cool and working for that grade, but not for general stopping.
One conclusion I've made is that D1 is not a good choice for engine braking; I'm so light in the rear that the wheels will slide and hop rather than drive the engine faster. Might be different in 4wd.
Old Nov 25, 2020 | 09:21 AM
oldbird1965
At about 65mph facing a hill I'll push the 'noise' button. If I get down to 45mph then I'll pull it into 2nd watching EGT's all the time. On the downhill side I just let it slow down at the top of the hill and use the brakes at intervals to let them cool inbetween. The new trucks, put it in D and go, simple. The OBS you have to work at it. I'm sure there are many, many who will argue with me over this but I have real life experience at 10 thousand miles a year for 15 years going across country. If I hadn't paid attention I would be in the ditch with a 5er on our heads.
Jose, I just don't know of a exhaust brake that would fit on a Irate T4 setup.
Old Nov 25, 2020 | 11:26 AM
ESwift's Avatar
ESwift
CNCFAB
Oldbird, nice to have someone with your towing experience, and realistic description of towing with these old trucks giving advice, thanks!
As far as an exhaust brake with a t4 kit, the inline pacbrake works(at least on 99-03, I would imagine it would squeeze in on an obs as well), it welds in the bottom of the downpipe. It is a stand alone unit, with its own compressor,tank, electronics etc. They work very well. I plan to install one on my 99 at some point
Old Nov 25, 2020 | 12:09 PM
oldbird1965
ESwift, thanks but I should of mentioned that was freeway driving. On back roads steep downhills and curves I don't hesitate to use 2nd for breaking. I should check out the pacbrake because sometimes I get real nervous, like when someone cuts in front of you when everybody up ahead is braking hard. I've had three OBS's and for some reason that I can't figure out this OX has the best braking of all of them and I've worked on the brakes on all of them.
