Sponsored by: Real Truck
Blower motor speeds
Old Nov 19, 2020 | 08:53 AM
pjl96's Avatar
pjl96
Blower motor speeds
Hey guys.
So I have a 2005 F250 with a 6 L
manual climate control
only low and high on my fan speeds have worked for a long time but recently they stopped working altogether. I had found out that the fan control switch on the backside was melted along with the pigtail. So I replaced the pigtail and the switch and I also replaced the resistor. The blower motor itself I had replaced a few months ago. After replacing the resistor, and the pigtail and control switch today, all fan speeds worked for about five seconds, and now I only have low and high fan speeds again. What do i look for next?
Old Nov 19, 2020 | 10:05 AM
Djosbun's Avatar
Djosbun
Sounds like you have some high resistance somewhere in the circuit. Are all terminal connectors clean and free of crusties? Any wire damage? Signs of critter chewing? I would measure for voltage drop between different points in the circuit to locate the problem area.
-- Dave
Old Nov 19, 2020 | 10:15 AM
pjl96's Avatar
pjl96
-- Dave
All wires look clean. Behind the dash i don’t see any damage, and from the resistor going towards the firewall, all those wires look fine. No crusties anywhere.... i don’t know what’s going on. Pigtail at the switch is new, along with the switch. the pigtail at the resistor is new also. Along with a new resistor
Old Nov 19, 2020 | 03:22 PM
Fatz29708's Avatar
Fatz29708
Common issue, check the corrosion on the connections to the resistor on the blower motor.
Old Nov 19, 2020 | 08:44 PM
pjl96's Avatar
pjl96
All connection points are new. No corrosion anywhere. New blower motor, new resistor, new resistor pigtail, new fan switch, new fan switch pigtail
Old Nov 20, 2020 | 10:07 AM
StrokedRanchero's Avatar
StrokedRanchero
I"m thinking blower motor drawing more amps, On it"s way out.
EconolineFan
Mar 13, 2012 02:36 PM
sparrky81
Jun 26, 2011 07:02 AM
puck1263
Jul 5, 2006 11:21 PM
175Ranger
Feb 12, 2004 07:49 PM
99lightning
Aug 12, 2002 03:52 PM
