brake, abs, traction control warning lights
Old Nov 18, 2020 | 08:27 AM
murraycookies's Avatar
murraycookies
2017 F350 6.7
Brake, abs and traction control warning light came on. Also trailer assist brake not working. Any idea before I take it to the shop?
Old Nov 18, 2020 | 11:13 AM
xxxsherpa's Avatar
xxxsherpa
The plug above the spare tire seems to cause many similar problems, search for this.
Old Nov 18, 2020 | 06:50 PM
KU4OJ's Avatar
KU4OJ
Had a Ford mini-van do the brake-ABS-Traction Control thing. Turned out it was low brake fluid. But it could have been more expensive, like a wheel speed sensor will set the same warnings. Have you had anyone working on brakes or changing tires? Running through heavy brush a stick or limb could get a lucky shot at the backside of the wheel speed sensor.
Worth a shot.
Old Nov 21, 2020 | 05:53 AM
crmitche's Avatar
crmitche
When I swapped my load levelling/sway control from the F150 to the F250 I had the same thing. It also disabled the cruise control. I backed spring tension way off and currently only have enough to keep enough friction for the sway control. Haven't had the issue since.
Old May 20, 2025 | 04:04 PM
ShiftyJosh's Avatar
ShiftyJosh
1st Gear
My issue solved.....
Real late but i was dealling with this issue for a year. No abs, cruise control, rear sensors when backing up amongst other issues. I had a code for bad drivers abs sensor. Changed it and immediately cleared up my issues. After reading lot about this issue on various boards was glad to know its a ford thing.......and usually an abs sensor.....
FourXFords
2009 - 2014 F150
Apr 14, 2017 12:02 PM
boblewis
Mar 2, 2012 07:58 PM
SasquatchF-250
General Automotive Discussion
Jun 28, 2011 09:35 AM
WorldCommander
32
Aug 25, 2008 05:17 PM
roree
Aerostar
Apr 9, 2004 12:54 PM
