56 F100 Project
Old Jun 21, 2023 | 11:41 PM
abe's Avatar
abe
Originally Posted by EBEAR
Rarely does salvaging a tank work out for the better . After a number of filters , fuel lines , pumps and carb cleanings most end up buying the tank .
Agreed. Buy a new tank.
Old Jun 22, 2023 | 06:44 AM
CharlieLed's Avatar
CharlieLed
I know that you said that you were looking to build it back stock but you may want to consider an under-bed fuel tank. On my 56, when it had the stock tank installed, I felt like it took up a lot of seat room inside the cab and the sloshing of the gas was annoying to listen to while driving. Some folks are also a bit concerned about having that much flammable liquid inside the cab with them. A tank in the rear also adds weight where it is most needed.
Old Jun 23, 2023 | 10:46 AM
Grelda1975's Avatar
Grelda1975
Thanks for the replies. The tank hit the bottom of the metal bin at the dump yesterday.
Layed Out 100
Mississippi Chapter
113
Oct 24, 2023 07:52 AM
jt45e
Apr 6, 2019 08:00 AM
rpm56
32
Mar 25, 2018 03:12 PM
56FOneHundred
55
Oct 5, 2011 11:48 AM
Drewski 2
15
Jul 17, 2011 10:43 AM
