Battery light illuminated
Old Nov 14, 2020 | 03:52 PM
jd58980's Avatar
jd58980
This may have been asked a million times and I even searched for it but found now thread.
2002 7.3L.
New batteries and new alternator
alternator charging at 14.5 volts. Battery light on dash stays on constantly.
How do I get it to go out?
Thanks in Advance.
Old Nov 14, 2020 | 05:39 PM
seville009's Avatar
seville009
based on other similar posts, might be broken alternator wiring, so check all the wires.
Old Nov 15, 2020 | 09:57 AM
pirate4x4_camo's Avatar
pirate4x4_camo
the "broken" wire is usually the fusible link that is at the solenoid on the inner fender, the other typical alternator wiring fault is the plug into the alternator, not the charge wire but the connector, since your alternator was recently changed that means that connector was unplugged and that is what usually causes them to fail.
oldfangle
Electrical Systems/Wiring
Jul 11, 2024 01:30 PM
KirstenxMarie
Nov 18, 2022 07:50 PM
Diverdan0430
Jun 19, 2017 02:30 PM
cornfeed
Feb 1, 2005 04:51 PM
