Powering down accessories?
Old Nov 11, 2020 | 01:28 PM
Daddy454's Avatar
Daddy454
Anybody else do it?I have long been in the habit of turning off all acc. on my rigs before I turn off the engine-a/c,heater,heated wheel,etc.I have tried pointlessly forever to get the wife on board as well,but we all know to pick our battles.My theory is less strain on the starter/electronics/whatever at startup,but this may also be nothing.I've done it so long,I don't remember when/how it started.Just curious if anyone else does this,and why?
Old Nov 11, 2020 | 01:44 PM
Mike_in_STL's Avatar
Mike_in_STL
Everything is computer controlled now and the computer will not allow accessories to effect the system during startup. The vehicle goes through a boot sequence after the engine is started and alternator voltage has been confirmed by the intelligent power management system. There is no need to worry about powering things off in a modern vehicle.
Every single button runs to the computer before an action occurs.
Old Nov 11, 2020 | 02:44 PM
Lin19687's Avatar
Lin19687
Veteran: Navy
Finny, I got IN the habit of turning on my heater the way I wanted now that there is auto start
Old Nov 11, 2020 | 02:47 PM
ford390gashog's Avatar
ford390gashog
Even before being computer controlled the ignition switch bypassed the accessories during cranking.
Old Nov 11, 2020 | 04:00 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I've always been in the habit of it, but not due to "strain on startup"....but because I don't want to start my vehicle and be blasted with loud music, HVAC blasting me, lights coming on, wipers going, etc, etc...
Now that I have been car shopping...nothing sucks more than starting a car on the lot and the thing going crazy on max AC, radio on, etc...
Old Nov 11, 2020 | 04:11 PM
bk4gbay's Avatar
bk4gbay
Someone that understands me! lol I have been doing this on all vehicles for years. I don't know why I started that, but my batteries do last a long time... Got my wife to do it and was even shocked when I rode with my sister and she turned everything off. Said she remembers me doing it when I would take her to and from school.
Old Nov 11, 2020 | 04:16 PM
Crotchety Ford truck only's Avatar
This is true...................
Old Nov 11, 2020 | 05:31 PM
minke's Avatar
minke
During a normal truck shutdown my accessory GPS goes into a sleep mode instead of off. Sleep is intended to provide a faster startup but costs a little power from the GPS's internal battery while sleeping. With very little driving in the age of COVID the GPS's battery has gone flat a couple of times. There are two downsides. 1) The GPS doesn't have enough power for it's own normal shutdown so it can't send my phone the lat/long of the parked truck. 2) The batteries lifetime will be diminished and perhaps that will determine the GPS's lifetime. It is easy to do a complete GPS shutdown and I usually remember.
Old Nov 11, 2020 | 05:58 PM
wylecoyote's Avatar
wylecoyote
I have been doing this for years also. Glad I am not the only one,
Old Nov 11, 2020 | 07:16 PM
speakerfritz's Avatar
speakerfritz
same here
About 40+ years
Old Nov 11, 2020 | 08:10 PM
Andy_george's Avatar
Andy_george
I’ve been doing the exact same thing my entire life. Taught to me by my Dad. Perhaps we all need some group therapy? 😂🤷‍♂️
Old Nov 11, 2020 | 09:01 PM
Work Truck Fanatic's Avatar
Work Truck Fanatic
I do this too. I let my lift pump run until at least the the beeping stops. So I don't want any thing else drawing power during this cycle. It may be based on old thinking but an engine is an engine so I still do old rituals as long as they don't cause harm.
I let the lift pump run because I want verified suction pressure at the high pressure pump when it turns over even though I know the system is already primed.
Old Nov 12, 2020 | 01:18 AM
Daddy454's Avatar
Daddy454
Interesting stuff.Good to know.
This is part of my reasoning as well.
Old Nov 12, 2020 | 01:22 AM
Daddy454's Avatar
Daddy454
Funny to know I'm not alone.Again,I don't even remember when or why I started.Probably still do it just out of habit.
Old Nov 12, 2020 | 06:45 AM
Work Truck Fanatic
It's a lot like prefilling an oil filter at oil changes. Can I go without doing it because the truck is designed to handle not prefilling? Most likely yes. But it doesnt hurt and it may even help.
