Vinyl Repair
Old Nov 10, 2020 | 08:53 PM
Roadboss's Avatar
Roadboss
4wd Low
Vinyl Repair
Any suggestions on how to make repairs to a small tear in the vinyl arm rest? Small 90 degrees tear about 1 inch long each way. Anybody have experience with this? Appreciate any help.
Thanks, Tony
Old Nov 11, 2020 | 11:38 AM
lfabio's Avatar
lfabio
There are a few ways, with varying degrees of difficulty depending essentially on how long you want the repair to last. The 'best' way is to reach underneath with a piece of cloth about 1" per side larger than the tear (or, lacking that, a piece of vynil, but that will leave a bump), glue it in place with a vinyl glue to mechanically repair the tear, then on the exposed side you can use one of those 'vinyl repair' tinted products to blend the surface of the cut, so to speak.
Use an appropriate glue for the cloth - the Plastidip VLP product is actually pretty good for this, so is Bostik contact adhesive (called 'super clear' in other countries).
