351M rebuild
Old Oct 23, 2003 | 09:00 AM
Redone's Avatar
Redone
351M rebuild
I have searched this forum for answers on rebuilding a 351M to a 400 but I haven't found anything specific, other than a 400 crank and pistons.
Is that it?
I'm just a little leary on swapping just those two items when I do my rebuild. It just sounds too easy.
Thanks.
Old Oct 23, 2003 | 10:10 AM
Bill_Beyer's Avatar
Bill_Beyer
You won't find anything more specific because that is the only difference between a 400 and 351M. As I've said before, turning a 351M into a 400 is the easiest & cheapest stroker motor you'll ever build. BTDT, got the T-shirt.
Old Oct 23, 2003 | 10:31 AM
Redone's Avatar
Redone
Cool!
By-the-way, you posted some photos showing a modification to your 400. It looks like something that improves the oiling system to your motor, right?
Old Oct 23, 2003 | 10:36 AM
Bill_Beyer's Avatar
Bill_Beyer
Yep I did. I put that together based on feedback I'd gotten here as well as from an engine builder friend and other sites regarding the Cleveland oiling system modifications. You can buy a kit to do it for like $100 or so but I bought the parts from my local speed shop for about $35.
Old Oct 26, 2003 | 11:27 AM
89_4drbronco's Avatar
89_4drbronco
I have a 89 351 can i swap the crank also to make it a 400? would i need to change the computer or anything else to make it run correct? thanks rich
Old Oct 26, 2003 | 02:59 PM
Brian S's Avatar
Brian S
'89 Broncos would have a 351W
so you're on the wrong engine forum. A 400 crank can be made to fit but it requires a lot of modifications. You don't need a 400 crank because there are countless aftermarket stroker options for your engine, 372, 383, 393, 408, 418, 426, 435 etc.
Old Oct 26, 2003 | 03:06 PM
89_4drbronco
thanks.i heard thats the better one right? i was even thinking about swapping a diesel in it if thats possible? thanks rich
