windshield wipers acting weird
Old Oct 23, 2003 | 05:04 AM
redneckdieselmechanic's Avatar
I just picked up my 84 F 150 from shipment out here to hawaii. I noticed the wipers dont work at all. I have the intermittent wipers by the way. When i turn em on to high, i can hear a clicking from the control box up under the dash, and can see the interior light dim a little and the ammeter go down a little. I guess theres volts going to the motor and it gets warm if i leave em on high for a couple minutes. I've replaced the brain box once (connects between the switch and the motor) because it went bad, the intermittent function didnt work. Could that be my problem? Or maybe just a bad ground?
Old Oct 23, 2003 | 06:30 AM
bremen242's Avatar
bremen242
sounds like the motor could be locked up, or a bad ground. try apply power manually to the motor (but make sure you disconnect the wires coming from the control box, so you don't blow it out).
Old Oct 26, 2003 | 03:39 AM
I tested the motor...it was bad like you said. Its good now, got me a new one from napa
Old Oct 26, 2003 | 06:27 AM
bremen242's Avatar
bremen242
cool.. your ready for the rain and snow now
