Help !
Thanks for all the info I have received on the site. Anybody ever had issues with aftermarket fobs creating havoc on keypad not accepting code to unlock Excursion? Mines going haywire some actuators cycling but can’t get into truck. It is not running but key is in the ignition
Thanks
jonathan
Crawl under it and disconnect the battery cables, give it 10 minutes or so, and reconnect them. Then hope the key pad works.
I think I would be careful and take the positive off the starter.
Thanks, squared away for now. Had windshield replaced 2 weeks ago, hoped it was causing the problems. Will up date for future reference, for those that want to reference. Still have leak passenger side, glove box wet. Examined above glove box and drip coming from joint in ac/heat plastic channel.
Thanks
Jonathan
