CAMPER PACKAGE question
Old Oct 29, 2020 | 01:43 PM
Kenny Bania's Avatar
Kenny Bania
Two questions regarding the "CAMPER PACKAGE 160.00":
1) Does it change the Pillar Sticker Payload number?
2) Does it improve real world payload or REAR END towing performance, (independent of any paper change listed on that sticker)?
Old Oct 29, 2020 | 01:56 PM
ford390gashog's Avatar
ford390gashog
The answer is no to both. Its a certificate and a rear sway bar. The swaybar is worth the option.
Old Oct 29, 2020 | 02:00 PM
Kenny Bania
So it doesn't reduce paper payload even by adding swaybar etc? Everything else seems to, so that's weird.
Also, note: "Rear auxiliary springs (F-250 only; standard on F-350)" You are saying it doesn't actually include an additional spring?
Old Oct 29, 2020 | 02:19 PM
samuse's Avatar
samuse
It gives heavier front springs, overloads on F250, and rear swaybar.
I would imagine that payload would be reduced by whatever the additional stuff weighs, but it's not much.
I always get the Camper Package because I like the heavier springs and swaybar. Additional stability is always a plus for me as I'm always on the highway and/or on pretty flat ground Serious offroad guys don't want swaybars because they want the extra articulation at low speed.
Old Oct 29, 2020 | 02:21 PM
Kellem's Avatar
Kellem
Was under the impression it also included increased capacity front springs.
not knowing the numbers, would think increased payload with the upgrades compared to standard F250.
Old Oct 29, 2020 | 02:25 PM
Kenny Bania
Thats the point of the thread really.
It probably does increase "real world" payload, at the same time reducing "paper" payload to stay under GVWR. Everything you add will reduce payload if you have a GVWR rated truck.
Do the experts think the sway bar and springs actually HELP loaded towing? My supposition is yes.
Old Oct 29, 2020 | 02:54 PM
Bill Tex's Avatar
Bill Tex
F250 or F350?
Old Oct 29, 2020 | 03:20 PM
Kenny Bania
Originally Posted by Bill Tex
F250 or F350?
Yeah I should have stated up front F250. I know the F350 already has the overload spring of course. Which we all know is one of several components that raise payload on the one ton from the 3/4....
This thread is partially a roundabout way of asking ... how much is that overload spring (and the front too) helping with real world hauling capability.
Old Oct 29, 2020 | 03:25 PM
ford390gashog
I didn't think you got past 5200 springs on a F250 without adding the snow plow option?
Old Oct 29, 2020 | 03:32 PM
Kenny Bania
The Camper Package is optional on XL, XLT, LARIAT and King Ranch®, Platinum (DRW)
Includes:
• Extra heavy-service front springs (4x2) (2-up upgrade above the spring that has been computer-selected based on other selected options. Not included if maximum springs have been computer-selected as standard equipment.)
• Heavy-service front springs (4x4) (1-up upgrade above the spring that has been computer-selected based on other selected options. Not included if maximum springs have been computer-selected as standard equipment.)
• Rear auxiliary springs (F-250 only; standard on F-350)
• Rear stabilizer bar (SRW only)
• Slide-in camper certification
Old Oct 29, 2020 | 03:35 PM
Bill Tex's Avatar
Bill Tex
Right. The Camper/SP Package is a bargain.
Old Oct 29, 2020 | 04:42 PM
Joe T's Avatar
Joe T
Yeah more spring on the 250 will help the capability but doesnt change the registered gvwr.
You will need less options or go to a 350 if you want to increase the yellow sticker.
Old Oct 29, 2020 | 04:44 PM
_hedge_'s Avatar
_hedge_
If you're actually thinking of getting a camper I'd suggest it would be a good idea to get the 350. I can't think of any reason to get a 250 unless you have licensing issues that push you into other costs.
Bill Tex's Avatar
Bill Tex
OP; if your plan is to get a camper...then get the 1 ton.
Edit; hedge beat me to it by 10 secs...
Old Oct 29, 2020 | 04:55 PM
OffBalance's Avatar
OffBalance
I got camper package on my F-250. It gave me the 5600 pound front springs, overload leafs, and rear swaybar. And a piece of paper that showed the camper max weight, which is just the payload minus 750 pounds of passengers. The package also reduced the payload a little bit because of the extra steel included. Because an F-250 (except heavy towing) has a 10k GVWR, and the truck weighs 7000 or more pounds, you will have a smaller payload than with an F-350, as hedge and BillTex stated above. Most slide-ins will be too heavy for an F-250 unless you get an overlanding popup camper.
I was able to get a comparison to an identical truck to mine without the camper package. I am planning to create a thread on this when I get the pix downloaded sometime...
