Help Diagnose 4X4 problem
Old Dec 2, 2000 | 11:15 PM
jamden's Avatar
jamden
Would appreciate some help with diagnosing a problem. I have 1992 4X4, Ford manual hubs, Dana 44 with 3:55's and NP 13-56 transfer case. The hubs lock easily and the 4X4 still works in both hi and low range. But it makes a "clunking" noise when pulling or under load. It is doing it in both hi and low range. It seems to do it only on rough surfaces that cause the tire to move up and down, not necessarily bounce, just move up and down. It sounds to me like it is coming from the drivers front side. I'm guessing that something is going but don't know enough to say if it's in the hub assembly or is one of the axle CV joints or whatever. There don't appear to be any similar noises at all from the area while in 2WD. Any help would be great. Thanks in advance.
1992 F150 Supercab SB 4x4 302 AOD 3.55 31x10.5 All Terrain on Ford 15x8 Ralleys
Old Dec 2, 2000 | 11:45 PM
PAUL_2's Avatar
PAUL_2
Inspect the U joints on the front driveshaft & both front axles . Since its only making the noise in 4wd Id concentrate on the front driveline components . Does the noise get worse , stay the same when you make a turn ?
Old Dec 3, 2000 | 12:08 AM
shotgun's Avatar
shotgun
Take a close look at your motor mounts and the Radius arm bushings. Check the shocks/mounts also. I have heard of loose rivet problems on Ford frame/front ends.
-Chris
Old Dec 3, 2000 | 01:53 AM
swenson's Avatar
swenson
I had a clunk in the front passenger side that turned out to be a loose bolt on the sway bar. Once it was tightened, the clunk was gone.
Old Dec 4, 2000 | 09:05 PM
fatforty's Avatar
fatforty
My 86 did the same thing and I couldn't find it everything looked fine as it got worse it was easy to find and it was a cv joint usually the outer one goes first but if you change one do them both and save yourself the problem of taking the axle out again. John (FATFORTY)
Old Dec 5, 2000 | 10:28 PM
jbhf250's Avatar
jbhf250
Old Dec 6, 2000 | 09:40 PM
jamden's Avatar
jamden
Thanks for the comments. I'll get it sorted out and post the results back.
fireball318
Modular V10 (6.8l)
Jun 4, 2013 05:10 PM
shaferz
Jan 28, 2012 10:45 PM
txbyrd
Sep 18, 2007 01:05 PM
TXpitdog
2004 - 2008 F150
15
Jul 18, 2005 08:52 AM
CO4x4SD
Aug 19, 2003 07:34 PM
