Bronco II Ford Bronco II
Rough Idle
Old Oct 22, 2003 | 05:40 PM
lombodml's Avatar
lombodml
Rough Idle
When I am at a light in drive, the engine seems to idle kind of rough. Any suggestions?
Old Oct 22, 2003 | 06:52 PM
Ken00's Avatar
Ken00
Could you tell us more details, year, engine, tranny, have you done a tune up, etc.
Old Oct 22, 2003 | 10:08 PM
lombodml's Avatar
lombodml
It is a 1987 Ford Bronco II 2.9 L Automatic. i just replaced spark plugs and air filter.
Old Oct 22, 2003 | 11:28 PM
mrshorty's Avatar
mrshorty
Probably the first check with any idle problem is to check/clean the Idle air control valve (sometimes called Idle speed control).
Second (maybe should be first), run EEC-IV diagnostic tests. Only requires a jumper wire and an analog voltmeter.
Another possible cause of idle issues, especially on this speed density system, is vacuum leaks. Make sure all the vacuum hoses are in good shape.
That should get you started.
