Break in limiter
Old Oct 24, 2020 | 09:12 PM
1tuff250's Avatar
1tuff250
Break in limiter
I test drove a 2020 F-150 3.5 echo 4x4 today and when I put it to the floor it only shifted at approx.5200rpm.Is there a break in limiter?
Old Oct 24, 2020 | 10:30 PM
irocdupi's Avatar
irocdupi
Great way to drive a truck you dont own, especially when its breaking in... No rev limiter, it shifts when it shifts
Old Oct 25, 2020 | 01:00 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Well . . . technically it has a rev limiter, but no different one for a break-in period. It's set to run the same right out of the factory as it will 50,000 miles later (if left unaltered).
Also, keep in mind the Ecoboost doesn't need a lot of revs to put out gobs of power and torque like the naturally aspirated engines do.
Regarding the breaking in period, I've driven plenty of these from the rental car lots and they have all been fine, and the police buy gobs of them as well . . . and I'm sure none of them were broken in nicely. I'm a fan of breaking them in nicely and do it when driving a new-ish vehicle, even when the manual says it is unnecessary. Most folks don't care and they seem to hold up fine.
Old Oct 25, 2020 | 07:37 AM
1tuff250's Avatar
1tuff250
Test drives are so you can see what the vehicle can do,I only held it for a few gears.I bought the truck and will pick it up monday.My 2016 revved to almost 6000rpms
Old Oct 25, 2020 | 08:44 AM
GABAR's Avatar
GABAR
More than likely the new 10 speed and maybe even the ring gear has something to do with the shift points.
Old Oct 25, 2020 | 04:27 PM
Robbgt's Avatar
Robbgt
2020 3.5 EB Peak horsepower happens at 5000PRMs while peak torque was back at 3500.
​​​​​​Likely how they programmed WOT shift points. Try sport mode and see what it does.
BeagleFord
Nov 14, 2015 08:39 AM
640 CI Aluminum FORD
2015 - 2020 F150
36
Feb 10, 2015 04:40 AM
Jon Wagner
2015 - 2020 F150
Jan 21, 2015 11:25 PM
Desmoface
2009 - 2014 F150
Jul 8, 2013 10:32 AM
