Sponsored by: Real Truck
Sag
Old Oct 22, 2003 | 05:36 PM
12.5/1's Avatar
12.5/1
Sag
What can I do to correct the rear end sitting low due to the plow package option? The truck is new is this norm?
Old Oct 22, 2003 | 05:47 PM
Yeti's Avatar
Yeti
Doenst sound normal, my 250 sat nice and level, and if anything, 1/2 higher in the rear, but un noticable.
Stock 250 usually sits about an inch to an inch and a half *** high, with the ex springs giving you around 1 1/2" of added hieght it pretty much levels it out.
How much are you talking?? could you step up to the 350 rear block to make it level???
Old Oct 22, 2003 | 06:10 PM
bellpr's Avatar
bellpr
My 02 F250 SD has the plow package and it sits level when not loaded....Only squats when I hitch up the RV...... Check out my thread about how do you stop squating.... I think some folks have mentioned this problem there...
Old Oct 22, 2003 | 06:58 PM
12.5/1's Avatar
12.5/1
I just noticed it today, have had the truck 2 weeks. I'll have to measure to be sure. It looks like 1/2 to 1 in. lower in back. The look is bumming me out.
Old Oct 23, 2003 | 08:11 AM
FortyFords's Avatar
FortyFords
I have never seen a nose high superduty either
unless loaded as stated before!
I would investigate this fully something is not right!
Measure the distance between the helper springs and the rubber bumper that they will hit when loaded ! give us the measurment.
Could be that south of the border steel again !
Rich
Old Oct 23, 2003 | 05:19 PM
12.5/1's Avatar
12.5/1
I just went out to measure it. It is 3 3/4 in. on the rear of the helper spring. Thats from the top of the leaf to the rubber bumper.
Old Oct 23, 2003 | 07:02 PM
FortyFords's Avatar
FortyFords
My mistake on where to measure!
We need the measurement from the rubber snubber on the frame to the block (theres a arm that the snubber hits ) under your springs .
Sorry
Does your truck have a rear swaybar?
Rich
