Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2016 Escape bushing replacement
Old Oct 23, 2020 | 10:44 PM
sbraatz's Avatar
sbraatz
It's getting near that time to replace the F & R sway bar bushings and end links on my 2016 Escape 2L turbo and I am wondering if OEM is the way to go or should I get poly bushings for a firmer better handling ride? I've used poly bushings on my other vehicles in the past and like the stiffer handling.
Any thoughts appreciated. Thanks.
Old Oct 26, 2020 | 05:27 AM
got2bjoester's Avatar
got2bjoester
I guess the real question is:
Do you like the ride the OEM bushings give you or not?
The sway bar ends on my 12 are at the same point and I've always gone OEM.
Old Oct 26, 2020 | 10:28 AM
sbraatz's Avatar
sbraatz
Over the weekend I went ahead and replaced the rear end link bushings and the F &R sway bar bushings with poly bushings. I prefer a bit stiffer feel and less sway in cornering. I've used poly bushings in the past on other vehicles and I've been pleased with the results.
Okiedokie
16
Jan 5, 2020 07:46 PM
remhaust
Sep 14, 2011 06:54 PM
Budman1962
Oct 22, 2007 05:29 PM
DIP51
Jan 31, 2007 07:54 PM
1984F15016
Sep 7, 2004 01:48 PM
