Tires
Old Oct 23, 2020 | 10:38 AM
Rod Valdez's Avatar
Rod Valdez
Angry Tires
Took to a dealer for michelin tires started cupping at 1500 miles. The service writer said i don't see cupping. i told him to get a micrometer to prove it is cupping. he said i have good eyes. i told him i've been doing this for over twenty years, i would do it myself but warranty would not pay me, because i am not ford certified. at end of day went back because had a call saying truck is done. i asked what was done. He replied just an alignment. i ask about the tires cupping he told me that it is normal wear. i told him that is not normal, he said if any problem that to come back, i said what about replacing tires? because when tires start cupping it is going to keep cupping. some people just like to get around repairing properly.i am waiting for tires start vibrating so i can go back. what do you people think about this?, what about customer service? where did it go? truck is 2020 f250 7.3l 4x4 crew cab.
Old Oct 23, 2020 | 12:15 PM
MDK993's Avatar
MDK993
My father in law had a very similar issue on his GMC. He went to the dealer, they told him to go directly to the manufacturer because they wont cover it. He went to the manufacturer and they said pound sand..... Unfortunately customer service sucks now a days and unless you have a really good relationship with the service manager you are most likely out of luck. Keep us posted and best of luck.
Old Oct 23, 2020 | 01:04 PM
MrMajestyk's Avatar
MrMajestyk
I'd contact the Dealer Principal or General Manager and ask them to follow up with the Service Manager
before you go to the Tire Manufacture and explain to them what Ford Service did not do
Old Oct 23, 2020 | 04:27 PM
Pugga's Avatar
Pugga
There are a lot of factors that can contribute to cupping. What do you think the issue is? They're LT tires, mine start to cup also if I do a lot of unloaded miles. I just rotate them every 5-10k miles to keep them evened out and life goes on. Try adjusting your tire pressure, see if that helps. If you run them at full pressure for a lot of miles when the truck is unloaded, or have them underinflated for the load, they're going to cup. If the alignment is good and you don't suspect any other parts are causing a failure (bad bearing, bad shocks, bad bushings), I don't know what you expect the dealership to do.
Old Oct 23, 2020 | 07:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Sounds like making a mountain out of a mole hill, especially if the cupping is so slight that you need a micrometer to check it... You got your alignment, now keep rotating them
I haven't owned a truck that didn't cup tires to some extent...new or used
Old Oct 23, 2020 | 07:14 PM
Joe T's Avatar
Joe T
Tried with some Michelins that wore very prematurely and the dealer sent me to Michelin and then vice versa.
I would just rotate them and adjust the tire pressure. Remember the pressure is set to be running at full gawr.
Old Oct 23, 2020 | 07:33 PM
matt167's Avatar
matt167
I work in a high volume, high end tire shop and see a lot of tires.. Fords will cup the tires more than Chevy or Dodge it seems, but they all do.. The key thing to do is simply rotate the tires every ~5k miles. Once rotated, the cupping will be spun off in short time before it's allowed to get worse and you keep on trucking. If you get cupping so slight you need a micrometer to calculate it, the tire does not get replaced. Rotate and let the tire wear flat on a different position and keep on trucking.. Checking the alignment was the correct repair
sd250mud
Nov 10, 2006 07:55 PM
Ed G
1983 - 2012 Ranger & B-Series
21
Sep 8, 2005 07:51 PM
kenp
1997 - 2003 F150
30
Oct 22, 2002 02:12 AM
justdrive1
1997 - 2003 F150
Nov 9, 2000 12:27 PM
