Performance Ignition Module
Old Oct 22, 2003 | 04:10 PM
1990Fordf150v8's Avatar
1990Fordf150v8
Question Performance Ignition Module
I've got a question on my 90 f-150 XLT x-cab 2x4 302EFI automatic with OD. Will this make any difference in performance? I saw a Holley performance ignition mod for 59.95 in the Summit Nov/Dec catalog.
Old Oct 22, 2003 | 04:20 PM
f100guy's Avatar
f100guy
no it is has the same stuff in it. you are talking about the tfi module right
Old Oct 22, 2003 | 05:02 PM
1990Fordf150v8
Yes I think it's the tfi it's under the dis cap. I've posted a new question on this same forum. Please take a look at it. Thanks again.
Old Oct 22, 2003 | 07:06 PM
DW2455's Avatar
DW2455
I have a 87' 5.0 i put the accel TFI mod. on mine and it starts and runs better, and i also belive it to be better quality than the replacement moduals from the local parts stores, they are suposed to give you a loger spark duration, the biggest difference would be to replace your coil and install a MSD ignition, which i'll be doing to mine when the new motor goes in. Hope this helps DW
Old Oct 22, 2003 | 08:06 PM
1990Fordf150v8
DW what do you mean by it runs better with the accel TFI Mod?
Old Oct 22, 2003 | 09:20 PM
DW2455's Avatar
DW2455
well i already had a k-n filter and new exhaust, but i put the TFI mod and fuel pres. regulator on at the same time say its hard to say which one did what but, overal its little more responsive and runs smoother, it not that it make just gobs more power, it just runs better. Hope that makes sense, another thing is , it had gotton to the point of being hard to start, especialy when cold, the motor wold spin and spin before it would fire-up, but after the i put the TFI mod. on, it now starts on the second spin even when cold. DW
4BYFORDF150
May 19, 2004 12:54 PM
fordextreme
Modular V8 (4.6L, 5.4L)
Apr 11, 2002 12:42 PM
95fordbronco302
1978 - 1996 Big Bronco
Apr 2, 2002 04:17 PM
isomb3
Mar 5, 2002 06:38 PM
muskyjohnson
Jul 29, 1999 10:33 AM
