Oil capacity...
Old Oct 20, 2020 | 03:59 PM
Jafo56's Avatar
Jafo56
Oil capacity...
I'm just curious....I have a 2016 f-150 ...5.0.... the oil capacity states. 7.7 qts....how many guys just make it 8....was wondering about this....
Old Oct 20, 2020 | 05:03 PM
SpencerPJ's Avatar
SpencerPJ
Chances are 7.7 didn't come out. I'd go 7.5, check it the next day. Over capacity leads to bad things too. Personally I'd rather put 7 in and check the next day. After you get a baseline, you'll be good going forward.
Old Oct 20, 2020 | 05:40 PM
Jafo56's Avatar
Jafo56
That's exactly what I have done since I bought it new.....7.5..... then I always check it the next day and then periodically........ thanks for the feed back...
Old Oct 20, 2020 | 05:49 PM
GABAR's Avatar
GABAR
I have the same engine and year F150 as you.
I’ve always changed my oil myself and I never just use 8 quarts.
I really don’t think you’d hurt anything by using 8 quarts but I wouldn’t make it a habit.
I always use the 7.7 and when I drain my oil, I always but the front of my truck on ramps and let oil drain until it’s not even dripping out of the oil pan and then I remove the filter and let them same thing happen.
Old Oct 21, 2020 | 04:55 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
For calculations sake, 7.7 quarts is ALMOST 2 gallons (1.925 gallons). If poring your oil into two 1 gallon containers is easier for you to measure, I would be much more comfortable with over filling by 0.025 gallons (0.1 quart).
Old Oct 24, 2020 | 01:26 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
The others above ^^^^^^^ have very prudent advice and I don't disagree with it, however, if it were me I'd happily add the extra 3.9% (0.3qt) and never worry about it. An extra half quart (6.5%) I might worry a little, and an extra quart or more (13.0%+) I'd drain the excess. 3.9% I wouldn't worry about. They leave a little room so they don't have a bunch of ruined engines from oil change shops that get in a hurry at the sacrifice of accuracy while going slightly over.
Some in-between advice: See where it ends up on the dipstick after refilling with 7.7 quarts and then running it a few minutes. If there's a tiny bit of room at the top, or even if it is very exactly on full, I personally wouldn't hesitate adding only 0.3 quarts, even on a 5-quart engine.
My $0.02 .
Old Oct 24, 2020 | 08:10 AM
Excelerater's Avatar
Excelerater
I been dumping in 8 quarts in ,no issues..check the Dipstick its perfect
Old Oct 24, 2020 | 10:08 AM
pdqford's Avatar
pdqford
My $0.02 .
Ditto.
Or I was going to suggest next oil change put 7.7 qts in, run it, let it sit overnight, pull the dipstick and take a picture of it.
Then add the other 0.3 qts, run it, let it sit overnight, pull the dipstick and take a picture of it.
Can you see any difference in the two pictures?
Old Oct 24, 2020 | 10:35 AM
nddragon01's Avatar
nddragon01
8 quarts. No issues.
Old Oct 24, 2020 | 10:57 AM
ford390gashog's Avatar
ford390gashog
Dump 8 quarts and move on. Life is far to short to measure fractions of a quart. Besides realize the stock pan holds almost 11 quarts before the oil is near the crank. Lots of Mustang guys run 10 quarts on the track.
Old Oct 24, 2020 | 12:09 PM
Jafo56's Avatar
Jafo56
Ok got ya...thanks for the feed back guys........
65navyf100
Mar 15, 2020 05:12 PM
MBBFord
Mar 28, 2015 09:29 AM
Randy777
Mar 27, 2012 03:23 AM
TexasTrash
Feb 24, 2010 11:30 PM
