Rear springs
Old Oct 18, 2020 | 06:09 AM
D2hm's Avatar
D2hm
Rear springs
I have a 2000 Navigator with the load level suspension removed. I regularly carry 300# + and often have 7-800#'s. What kind of springs can I put in to handle that load?
Old Oct 18, 2020 | 08:53 AM
alloro's Avatar
alloro
Look for "Variable Pitch Springs"
Old Oct 25, 2020 | 02:10 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You could install air shocks.
Old Oct 25, 2020 | 05:33 PM
Spaznaut's Avatar
Spaznaut
Are you sagging a bit? The Navigator is typically a 'soft' ride for comfort. You may have to look for options and see if there is a difference in the nav and exp spring rate. I think Monroe makes a spring assisted shock that could boost you up some. I used some in my little Astro van years ago and they worked very well. BTW is the '00 Navi irs or solid rear axle? I know the Exp. is still solid axle in those years.
Old Oct 29, 2020 | 12:22 AM
CathedralCub
FTE Community Team
They both got independent rear suspension for the 2003 model year.
miottimouse
Aug 14, 2010 08:20 AM
gotmudd?
Jan 21, 2007 06:37 PM
big blue 95
May 4, 2006 11:06 AM
RobPStroker
Oct 6, 2005 01:13 AM
badass_dodge74
Apr 30, 2003 02:36 PM
