Complete late model 223 engine. This is the updated version that solved the oiling issue. I believe it is a 1961. Turns over. I had it started a couple years ago. Ran it for a few minutes. I believe the engine has a blown head gasket. Comes with distributor, Holley 1 Barrel, intake and exhaust manifolds, bellhousing. Not sure which transmission the bellhousing is for. I searched for this engine for a few years and then had my 262 rebuilt instead. $350. Whittier, CA. I have it listed on Los Angeles Craigslist as well. Send me a private message or text me at 562-457-8794. Sean
Complete late model 223 engine. This is the updated version that solved the oiling issue. I believe it is a 1961. Turns over. I had it started a couple years ago. Ran it for a few minutes. I believe the engine has a blown head gasket. Comes with distributor, Holley 1 Barrel, intake and exhaust manifolds, bellhousing. Not sure which transmission the bellhousing is for. I searched for this engine for a few years and then had my 262 rebuilt instead. $550. Whittier, CA. I have it listed on Los Angeles Craigslist as well. Send me a private message or text me at 562-457-8794. Sean
