Sponsored by: Kumho
Lift Kit question
Old Oct 17, 2020 | 01:50 PM
Rcharity's Avatar
Rcharity
Lift Kit question
My 2016 F-150 has 35" tires on it with a front level kit...still getting some rubbing when driving on my buddies hunting properties.
Will a 4" lift create enough clearance to stop the rubbing? I ideally don't want the 6' lift if I don't have to put it on.
front inside wheel wells have already been trimmed some to minimize the rubbing.
Thanks in advance for any advice.
Old Oct 31, 2020 | 07:57 PM
AK4x4's Avatar
AK4x4
Something like this; https://skyjacker.com/shop/suspensio...#configuration is good for 34" tires. So since your truck has some trimming you may be ok with 35" tires. Without trimming, it usually requires a 6" kit to accommodate 35" tires. Good luck, Russ
Old Nov 7, 2020 | 06:58 AM
projectnitemare's Avatar
projectnitemare
Depends where the rubbing is and the wheel you are using.
Gary86
2009 - 2014 F150
Sep 3, 2010 08:12 PM
1st_FordTruck
2004 - 2008 F150
Jul 13, 2006 09:59 AM
goldman
17
Feb 5, 2006 09:58 PM
daddzwaterboy
May 6, 2004 10:12 PM
